[FIX] FS Beam
emagdalenaC2i
Member, Developers, Channel partner Posts: 860 ✭✭✭✭✭
Hi @NeilCooke
There is a small bug in the Beam FeatureScript
To fix it, just replace in the "Beam Feature" tab the line 105:
if (!definition.setCustomName)to
elseThis is the code I use:
<div>if (definition.profileType == ProfileType.CUSTOM)</div><div>{</div><div> annotation { "Name" : "Override", "UIHint" : "REMEMBER_PREVIOUS_VALUE" }</div><div> definition.setCustomName is boolean;</div><div> if (definition.setCustomName)</div><div> {</div><div> annotation { "Name" : "Name", "Default" : "Custom Profile", "UIHint" : "REMEMBER_PREVIOUS_VALUE" }</div><div> definition.customName is string;</div><div> }</div><div>}</div><div>else</div><div>{</div><div> annotation { "Name" : "Standard", "Default" : false, "UIHint" : "REMEMBER_PREVIOUS_VALUE" }</div><div> definition.nameStandard is boolean;</div><div><br></div><div> annotation { "Name" : "Profile", "Default" : true, "UIHint" : "REMEMBER_PREVIOUS_VALUE" }</div><div> definition.nameProfile is boolean;</div><div>}</div>
Un saludo,
I used:
Feature versioned - thanks for finding this.
https://www.youtube.com/watch?v=tn3-0H63RfQ
