ISO 14581 and other missing screws in the standard library
We have been testing OnShape for a few weeks and it seems like there are a lot of generic screws missing from the screw library. Is there a plan to add common screw types like ISO 14581, DIN 7045 etc?
As an addition it would be cool if the common Bossard screws were directly integrated like WN1452, Delta PT, among others?
In order to manage it a search field within the screw menu would be very welcome.
There seems to be a lot of hanging requests in this thread as well: https://forum.onshape.com/discussion/comment/58533#Comment_58533
3
I manage the standard content library for Onshape. Can you submit a ticket with a list of fasteners you and your team are looking for? We're working on something orthogonal to this now, but plan on getting back to standard content requests very soon.
As for specific supplier stuff, that is a bit more complicated (for every reason you can imagine). Generic standards are the best way to get these through the process.
We are hoping to have a mechanism in the future to give your team the supplier-specific content you want, but the best way to manage these for now is shown here: https://learn.onshape.com/learn/article/best-practices-for-managing-custom-libraries
Thanks for the reply. I think the most used ones in our industry are, ISO: 14581, 14583, 7046, 7045, 4762, DIN: 7500 (C & M), 7984
I agree that the DIN and ISO standards are best. Bossard does have the WN1452 series of screws which are really common and close to being an industry standard. Also something which is getting used more and more is the BN 9524 type low head screws.
It would be really great if there was a search tool in the screw library part of OnShape for when you have a lo
Is there a list somewhere where I can vote, I am brand new to OnShape and we will begin implementing it from January. Thore from OnShape just said to post here.
Best regards,
Frederik
I've looked around for ISO or DIN standards for thread forming screws for plastics, and haven't found a good reference. However, consumer electronics, medical, automotive, etc. all use such screws. Onshape has PEM fasteners in the standard parts, despite them being proprietary.
McMaster sells M1-M6 Delta PT screws: https://www.mcmaster.com/screws/rounded-head-style~pan/stainless-steel-thread-forming-screws-for-thin-plastic/
And McMaster has machine screws down to M0.5. https://www.mcmaster.com/screws/system-of-measurement~metric/thread-size~m0-5/
McMaster has a very wide variety of parts, but they are far from a miniature hardware specialist.
Best regards,
Frederik
Of course this means having a lot more screws to choose from so they makes it even more useful to have a search function for screws.
Depending on the application, sometimes the CM will want the screws to be magnetic for ease of picking up for electric screwdrivers, and other times that may cause more trouble than it’s worth.
Material and plating is one of the issues I see with the standard library. There are so many options, and some of them are regional (certain steel grades or plating materials are not common in some countries). To some extent I want the 3D to be independent of the material/plating specs.
Is there any progress regarding the addition of ISO and DIN standard screws to the library this is still a must have which is missing from Onshape?
