Retain Part / Surface ID.
Model revisions that occur higher up in the feature tree often change the surface ID of parts / surfaces, resulting in subsequent feature tree failures.
Example: I roll up and split a surface. The split then changes the part ID causing any existing solid extrudes that were intended to be added/ removed to lose their reference and need to be relinked.
This happens way too often and rolling through 600+ features again every time the surface ID changes is frustratingly time consuming.
Send help!
Send help!
7
IDK if OS does similar. I do notice when performing a union operation, you can re-order the selection inside the window. Does the order of that selection matter in OS?
