Still seeing MM and not inches
jack_erhart
Member Posts: 140 ✭✭
in General
I changed my prefrences to show imperial inches, but when I draw a line or any other shape, it shows in MM.
The CAD drawing I imported into my document was drawn in MM.
Is that the issue?
And how do I scale a full sized CAD drawing of locomotive parts to the size I want to model?
Thanks.
Is that the issue?
Thanks.
About scaling , including explanation.
Example.
I'm doing 3D printed models that are about 3' long. Proportionally, do I go into the imported CAD drawing, pick something like an overall length and use the dimention tool to change that, exspecting everything else to size properly?
https://forum.onshape.com/discussion/7179/part-scaling-in-onshape
I'm not sure if we are on the same page. The CAD drawing I have for a locomotive was drawn in full scale. In other words the actual size of the locomotive. What I'm asking is, how do I scale all the components in the one drawing so that they all scale down to the scale I want?
Example.
Thanks again for your help.
