Editing logic breaking reference to variables in array parameter?
Both of these custom features have array parameters: Texture & Freeform Spline. Input variables are lost when a new array item is added. Is there a way to fix this?
@Evan_Reese, you may be interested in the solution to this if there is one.
Alex_Kempen Member Posts: 251 EDU
The value of sortXReturned (and sortYReturned and so on) should have no bearing on whether your variables are getting overridden. Rather, it's the statement definition.groups[g].sizeX = storeSizes.x that's tripping you up, since that's setting the value of definition.groups[g].sizeX to the saved value of definition.groups[g].sizeX, which doesn't include the necessary variable information, even if the values are technically the same. The solution, therefore, is only to override the variables when the override value is actually different from the input value:// if definition.groups[g].sizeX is already the correct value, leave it alone! // if storeSizes.x is zero and autoScale.x is different from definition.groups[g].sizeX: if (storeSizes.x == 0 && !tolerantEquals(definition.groups[g].sizeX, autoScale.x)) { definition.groups[g].sizeX = autoScale.x; } else if (!tolerantEquals(definition.groups[g].sizeX, storeSizes.x)) { definition.groups[g].sizeX = storeSizes.x; }
Don't forget to repeat the following code for sizeY and sizeZ as well.Software Developer at Epic Systems
FRC Design Mentor - Team 1306 BadgerBots2
To prevent this from happening, add conditions to shield parameters from being updated unless they actually need a new value:
I suppose this behavior could actually be used desirably to selectively break variable references or move variables to an internal parameter. Of course, that's a very specific use case, but you never know.
Near line 3201 in the Texture feature:
Also, as a more general note, using 0.999 * inch as the indicator for whether the feature has been scaled is low key not great. I would recommend using a hidden map to store that information instead - it should be more reliable and silent to the user.
I don't care too much about the name of the config so I can simply delete code at line 3158. However, I do not want to get rid of the functionality from lines 3195 and 3206. I have tried placing them in an if statement so that they only return if something has changed, however if they return at all, they break the previous groups reference to the users variables.
Line 3158, name is changed in edit logic then returned to the hidden parameter above.
Line 3195
Line 3206
Here is the code that seems to be working, I will need to tweak it some more:
