"Add selection to folder..." missing when it should be available
If I select instances which include subassemblies, "Add selection to folder..." only shows up if I don't also select the instances under the subassemblies. The minute I do, the menu item goes away. This is really annoying when I have a zillion things I want to add to a folder and some are parts and some are subassemblies. (This is from importing ECAD which I don't control).
To be clear, I would like both selections shown below to allow me to "Add selection to folder..." and do the same thing.
Discrete selection works:
Continuous selection doesn't:
I honestly was very confused why the folder option didn’t show up. It makes more sense now, but since this is a new feature, it’s weird feeling like I just saw that command on a menu but now it’s missing. I had to read through the right click menu over and over to realize that the command was missing.
