#Diam+30 this expression is not work. please solve this
harish_aahaní
Member Posts: 4 EDU
#DIAM + 30in
or
#DIAM + 30mm
or whichever units you prefer.
RENDERCAD
For example, if #DIAM is set to be a length variable, then the added on number also needs to have length units such as in, mm, etc.
If it is an angle variable, the added on number needs to have deg, or rad after it.
If you need further help, please share a link to your document so one of us can take a closer look and provide a solution.
