How to create a notched bend in a sheet metal part?
jim_wilson436
Member Posts: 23 PRO
I'd like to incorporate a "notched bend", as illustrated below, in a sheet metal part where a cutout needs to be closer to a bend than the bend clearance would normally allow. But every approach I've tried so far has been horribly clumsy, requiring several features and sketches, moving faces, etc. Can you think of an elegant way to do this?
Keep in mind that things that are half-sheers or rips in sheet metal often behave better in Onshape (and other Parasolid based CAD programs) with a tiny gap. It can be microscopic, but there needs to be a little gap.
Just another way to do it.
https://cad.onshape.com/documents/685ca4a1228e3b6106ed4ab3/w/5edc18bc39110f1cf90d70c1/e/7cca3db60c51b022ea8c9619
