Pattern Around a Full Part
sam_biddle
Member Posts: 20 ✭✭
I'm working on a very simple part that I would like to pattern/texture. I was looking at the surface pattern script, but can only do one surface at a time. Is there a way to pattern the whole part surface so that the pattern is uniform around the whole outside of the part? Here is a look at what I'm trying to work with. Is there any way to put a helix around a part with flat surfaces also? Thank you.
sam_biddle
Member Posts: 20 ✭✭
This is very helpful. Thank you. Is there a way to make the texture bend around the cylindrical, filleted areas?0
As far as a helix goes, can you provide more details? If you would like a helix around your rectangular part, you can use Contour spiral by @konstantin_shiriazdanov. If you are wanting a simple spiral part, you can use Spiral or create one manually with a helix and a sweep.
RENDERCAD
I have not added "Morph" functionality yet. Only textures that are made for it will be compatible with Morph. It was at the bottom of my list of improvements, but if people are interested, I can bump its priority up.
What kind of texture are you applying? There may be another method to achieve what you want. Depending on the shape, you could split the surface, then thicken the texture to obtain a bend.
RENDERCAD
RENDERCAD
RENDERCAD
