What does this warning mean?
jack_erhart
Member Posts: 86 ✭✭
in General
Just did a bunch of work, and a warning came up that said. "Could not complete this function due to system limits."
Whose systems limits? Mine or Onshape?
All I was doing is creating faces off of a CAD drawing, and then everything I had done up to that point turned red, and the warning came up. I was creating a sketch, and could not confirm it.
All work lost :-(
In the past I had done much more creation then what I had just done, so I found it odd.
All work lost :-(
EDIT: if it's not that then it may be the sketch entity limit (can't remember what that is - 1000 entities?)
https://cad.onshape.com/documents/7692e358d58547b58a5acd56/w/77fcd3f4118dfdee6c528bc8/e/69debe85ad43860b804764b1
In sketch1 you import the dxf and you dimension 1 part, I did 1 wheel size R 350, the dxf was 1.22??? mm , so that resized the total sketch.
After that you can start making other sketches by selecting part's of the total dxf, you can do this by using the USE command, see help file for explanation.
You can also make other Part Studio's by using the derived command.
So the rule is , define the size of the original dxf , you only have to be sure about one size of the object, the rest resizes.
And to make it easier use only parts of the original sketch to make the solid part's
I'm modeling every thing full size, because I make different scale versions once completed.
