How do I turn off orthographic view?
carl_mcdaniel
Member Posts: 5 ✭
1
OptionsNeilCooke Moderator, Onshape Employees Posts: 5,411
Senior Director, Technical Services, EMEAI1
Personally, for me and the stuff I work on, this is "as it should be".
Orthographic projection in 3D is the MOST useful way to view a model when designing machines and equipment.
Perspective views are for customer presentations and artistic concepts. There is no real value to perspective projection in machine design. I've always treated it as a fancy tool to cure boredom for a few minutes before turning it back off and getting back to work.
One simple reason ortho is so useful is because when you want to check for alignment down the side of a system, all you need to do is change to a side view and glance. Which is impossible to do in perspective views.
For example: see this foot, from an ortho view you can see it is out of alignment from a glance.
Here is the same view in perspective. Even when you know the front foot is off by A LOT, it is still very hard to see from this view.
More examples would be while editing parts, you want to create relations to other features or parts. It is good to know when the faces are parallel and square. Something that is nearly impossible to tell from a perspective projection.
There are a few more reasons like: graphical glitches, camera panning and rotating clunkyness, etc. When it comes down to getting to work and being productive, prettiness is the last thing on my mind.
I'm sorry it is difficult for some people to understand an ortho model in 3D, but after a while your brain begins to ignore the fact it's ortho and what you see in your mind is a perspective view anyway. At least that is my experience.
To me, this looks natural:
This looks like someone knocked it over with a robot arm
For years, the mechanical CAD systems I've used (Pro/E->Creo, Solidworks) have had terrible implementations of perspective that are basically view only. You can kinda sorta do some work, but things are buggy, dimensions fly off into space and the UX is generally third rate, because the product testing team and engineering team never live in perspective mode. They just turn it on, see that it looks different, and turn it off. As users, we felt lucky when there where half-baked camera options to adjust the perspective.
On the other side of the CAD world, people who use Alias, Rhino, or any rendering or even architectural CAD (3D, not 2D) have lived in perspective their whole life. It hurts their eyes to see anything else.
Onshape needs to have perspective controls, but at least it works a little better with perspective turned on than Solidworks or Creo.
