is there a way of converting stl models back to a part file as in supported in FreeCad and solid wor
jonathan_easby
Member Posts: 1 EDU
Is there a method of converting .stl models back into a part model for modification, as is present in FreeCad and I believe Solid Works without redrawing the model using the stl as a template/guide?
