sharing specific version or revision
guy_rogelguy_rogel Member, User Group Leader Posts: 93 PRO
Is it possible to share only a specific version or revision with someone. so he can go over all the versions I have ?
  • john_mcclaryjohn_mcclary Member, Developers Posts: 3,944 PRO
    You can share the version if that is what version you are in when you copy/paste the link.
    if you don't want them to see the other versions, just make a copy of the document and share that copy instead, that will give you a blank version history.
  • guy_rogelguy_rogel Member, User Group Leader Posts: 93 PRO
    thanks John
    I was hoping for a better option  from copying my workspace. But I will try that
    Guy
  • ron_tisoron_tiso Member Posts: 4 PRO
    Do you mean "so he can't go over all the versions I have ?". Then I would vote for this.
  • Ignacio_Martos_Ignacio_Martos_ Member, Onshape Employees Posts: 18
    As @john_mcclary said the link sharing will point the user directly to the particular version or revision in which you copy the link. In the latest release of onshape we also added the ability to open to a configuration or state of the document, such as a flagged out sheet metal flat pattern or displayed BOM.
