line break in string?
EvanReeseEvanReese Member, Mentor Posts: 2,378 ✭✭✭✭✭
how do I add a line break to a string in FS? Is there a place I can go to see all of the formatting options available?
  • _anton_anton Member, Onshape Employees Posts: 444
    edited October 2021 Answer ✓
    \n
    println("Once upon a midnight dreary, while I pondered, weak and weary,\nOver many a quaint...");
  • Alex_KempenAlex_Kempen Member Posts: 251 EDU
    reportFeatureInfo and reportFeatureWarning messages don't handle line breaks and other methods of formatting like \b (for bold). On the other hand, it is possible to use template strings to display units properly, but that doesn't really help a whole lot with your use case.
    \n
  • EvanReeseEvanReese Member, Mentor Posts: 2,378 ✭✭✭✭✭
    ah! I had a backslash not forward. Thanks!
    hmm I thought that would solve it, but I'm still getting something else wrong. Here's what I'm trying to do, but it's still all one line:
    reportFeatureInfo(context, id, toString(roundToPrecision(wrapCount, 3) ~ " wraps. \n" ~ toString(roundToPrecision(wrappedDiameter/inch, 3) ~ " in wrapped diameter.")));
    Didn't know about template strings. Thanks, Alex! I feel as though I've seen features with line breaks in the reportFeatureInfo(), but it was a while ago and maybe that's changed. I think it's nice to have the option to format those.
    @Alex_Kempen
    I'm trying to implement the templateString, but it doesn't seem to respect the document units. I'm still getting meters. This is the code and result. Any ideas?
            var wrappedDiaString = templateString({'template' : '#dia#  wrapped diameter.', 'dia' : wrappedDiameter});
            // creating the messages
            reportFeatureInfo(context, id, toString(roundToPrecision(wrapCount, 3) ~ " wraps. " ~ toString(wrappedDiaString)));
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,232
    Sorry, TemplateString is for tables only.  And in any case, as soon as you call toString on it, it becomes a plain old string.
    Yeah, @ilya_baran is right. I guess I saw someone using template strings to format output once and assumed it worked without personally trying it.
    Got it. So is the best way to display valueWithUnits in a human way to just divide the value by whatever units I want to display and round it?
    Thanks, Ilya
  • chadstoltzfuschadstoltzfus Member, Developers, csevp Posts: 156 PRO
    I suppose if you really want to have error info to sift through you could throw out some println() or debug statements to neatly display the information you want. However since this display in the FeatureScript notices panel it's really more useful for the dev as opposed to the user, which it looks like is your target with this error message.
    chadstoltzfus@premiercb.com
    Yep. this is meant to be user-facing. We're working on a fabric that wraps around a spindle and I'm calculating how many rotations a given length of fabric takes to roll up and the diameter of the final spooled fabric. I'm using FS to do some calculations since it sounded easier to me than trying to set up a spreadsheet for it, and it's nice to have it right in Onshape where we're working. I'm not actually using the feature for modeling or setting variables.
