line break in string?
EvanReese
Member, Mentor Posts: 2,856 PRO
how do I add a line break to a string in FS? Is there a place I can go to see all of the formatting options available?
_anton
Member, Onshape Employees Posts: 523
\n
println("Once upon a midnight dreary, while I pondered, weak and weary,\nOver many a quaint...");1 -
Alex_Kempen
Member Posts: 258 EDU
reportFeatureInfo and reportFeatureWarning messages don't handle line breaks and other methods of formatting like \b (for bold). On the other hand, it is possible to use template strings to display units properly, but that doesn't really help a whole lot with your use case.Software Developer at Epic Systems
FRC Design Mentor - Team 1306 BadgerBots0
I'm trying to implement the templateString, but it doesn't seem to respect the document units. I'm still getting meters. This is the code and result. Any ideas?
var wrappedDiaString = templateString({'template' : '#dia# wrapped diameter.', 'dia' : wrappedDiameter}); // creating the messages reportFeatureInfo(context, id, toString(roundToPrecision(wrapCount, 3) ~ " wraps. " ~ toString(wrappedDiaString)));The Onsherpa | Reach peak Onshape productivity
chadstoltzfus@premiercb.com
