How to rotate all objects around X-axis by 90 degrees
matha_goram144
Member Posts: 11 EDU
in Drawings
Hello,
This is an elementary newbie question, sorry. I received a SolidWorks STEP file that I would like to rotate around the X-axis by 90 degrees to make Z-axis vertical. Is there a quick way to do this? Thanks.
Kind regards.
mahir
Member, Developers Posts: 1,320 ✭✭✭✭✭
Editing the import feature should impact downstream features/actions, including exporting. But if the orientation still isn't what you need, you can use a Transform feature to reorient parts/bodies however you like.2 -
mahir
@matha_goram144 , here's what the icons for the part and sketch transform features look like, respectively
1
Importing with Y up doesn’t just change the view, it orients the parts with respect to the origin and planes differently.
Transform is in all versions of Onshape. There’s a transform tool in sketch mode and one in part studio mode. In the desktop version, some tools are grouped together and will be in a drop down menu from the toolbar.
