My Sketch tools disappear.
When I add a sketch, the sketch tools appears. Everything is locked until I check the check box, then all the tools disappears and replaced with a new set of tools I have never seen before. PS you gave no direction on how to change the units. That took 30 minutes.
NeilCooke Moderator, Onshape Employees Posts: 5,904
When you created your account it asked you what units you want. Everything you need to know is here: https://learn.onshape.comSenior Director, Technical Services, EMEA1
