Color change in operation
maciekmaciek OS Professional Posts: 29 PRO
edited October 2021 in Product Feedback
Hi, I saw there was a request from 2015 to make it, but still it's not made. Could you make face/solid/surface appearance as operation like for example Sketch or Extrude? Color making is not parametrical so far and for me it's quite annoyng, because for example I can't make color changes in Configuration, or just simple when I delete some operations colors still exist in some faces.
    @maciek can you be more specific? Appearances can be added to faces and features now and can be changes with configurations. (under config properties).
  • maciekmaciek OS Professional Posts: 29 PRO
    Of course, sorry for long delay. For example I want to change color after extrude. So I would like to put this operation (color changing) before extrude operation.
    You can set a color to a feature
    Un saludo,
  • EvanReeseEvanReese Member, Mentor Posts: 2,358 ✭✭✭✭✭
    I made a feature that can do this. Here are some reasons to use it over the native color tools (which I still use for things):
    - It can be useful for configuring the color without having to configure every possible permutation.
    - I also like it to color faces when it makes sense in the feature tree. Sometimes if you color a bunch of things at the end, then roll your tree back some of the faces will maintain the color in ways that are confusing to look at.
    - It also gives you some other input methods like Hue, Saturation, Luminance.
    - you can color EVERYTHING in your studio at once, and only choose what not to color. I used this when designing a shed I built so all of the parts would look like wood even though there were new panels and beams being added all the time.
    Independent Onshape Consultant
    edited December 2021
    Nice. I like your icon, Could I used it?
    You can add RAL colors too. See my old RAL Color FS
    https://forum.onshape.com/discussion/11786/new-fs-set-color-also-ral-color
    Un saludo,
