Update Drawing Button
in Drawings
I'm hoping the update drawing button will go away and will become automatic in the future. If not, you should not be able to export any file type until its been updated or inaccurate information will be exported.
imagine.create.deliver
Some related areas where we'd like to hear more feedback from users are:
At this point I think that I would like to be able to right/click in the drawing tab and get some kind of an archive drop down. This drop down may possibly be within the properties section. Within this drop down I would like to see a list of the current and all previously archived revisions. I should also see an option to archive the current. and I should be able to access any of the revisions from this list.
As for being able to print, I think that we should be able to print all current and archived revisions. If watermarks are preferred by some then they should not be on the current or the last archived revision.
Changing model while trying to create drawing out of it can cause a lot of anomalies. I like the letter appearing on top if there is other users 'online'. Maybe that letter could hold some information on what they are working with; hovering letter could popup info like 'Tab: t1 Part: p1 Sketch: sk3' which would tell the others your where abouts and maybe even intensions.
How does dimensioning work in Ons drawings? If I have set dimension between two lines and those lines are deleted; what will happen to dim? What if lines are re-created?
Dangling dimensions can also be manually re-attached to view geometry by dragging the end(s) of the dangling dimension to a view snap point.
