Design for 3D Printing
patrick_sheapatrick_shea Member Posts: 63 EDU
I am trying to design a support for a 4" Plastic dust hose.  Apparently my design will require a lot of support, that will need to be removed after printing.  Looking for a bit of input an how I can make this easier to print.  It is a 1 off piece, so if it takes time to clean up it is not a big deal.  The design allows a couple of tie wraps to hold the hose on place.
Here is the part:
PLANER DUST HOSE SUPPORT | Part Studio 1 (onshape.com)
Patrick
    _anton_anton Member, Onshape Employees Posts: 279
    You could make a big 45-degree chamfer on the underside that goes right to the cradle's edge (0.77/2 inch, if my math is right).
    alnisalnis Member, Developers Posts: 449 EDU
    edited December 2021
    Edit: didn't see Anton's response; that's also a good option!
    I don't think the support is anything crazy in this case. It goes from 1:49 21g/$0.51  to 2:15 23g/$0.58 in Cura with typical settings for me. Probably not worth the time to optimize 7 cents off the print (assuming PLA), but you could try adding an angle with a sweep/replace face that matches the most extreme angle your printer can print. Alternatively, you could use a draft as an approximation. Here's the sweep/replace face example: https://cad.onshape.com/documents/1abe93154f1d0baa341b15c3
    Here's what your model looks like sliced with Cura:
    Student at University of Washington | Get in touch: contact@alnis.dev | My personal site: https://alnis.dev
    michael3424michael3424 Member Posts: 678 ✭✭✭✭
    If you really want to avoid supports, try splitting the part into the base part and the saddle part - print the base as shown, the saddle on edge and then glue the two together.  Printing with supports should be doable (and easier), though.
    nick_papageorge073nick_papageorge073 Member, csevp Posts: 676 PRO
    Slightly off topic, but you did a good job with the design.... if it was to be injection molded:)
    Edit, it could be redesigned slightly to make it all open-shut.
    I believe his design has the wire-tie in that space, and the chamfer would cause it to slip off.
    How about this design? Disclaimer, I'm not that good with 3D printing, and my printer seems to always have some issue. I come from an injection molding background for mass production. But this design might have enough draft on the sides and rounded surfaces at the top, that perhaps a printer would not need support at all? The wire tie goes through the slot and you would have to fish it out the other side.
    POCPOC Member Posts: 25 PRO
    FYI - If you print this on an SLS printer (sintered power) you will not have the support issue..
    Thanks for all the feedback - I re-thought my design, and I will lay it on its side for printing.  I need to have a strap (or Tie wrap) to secure the 4" hose - so check out plan'B'
    PLANER DUST HOSE SUPPORT - Copy | Part Studio 1 (onshape.com)
    Also - I have Cura and a Prusa printer I and getting used to, but I was wondering if anyone is using KIRImoto? And where does that file go when I export it?
    Pat
    dirk_van_der_vaartdirk_van_der_vaart Member Posts: 543 ✭✭✭
    Looks very good!!
    It's a bit difficult to put the Tie-wrap in the holes, so maybe 1 step further
    https://cad.onshape.com/documents/582a266db2197f91d5ed5378/w/2d044cfd5f225a8c7289dfa4/e/5b8bb3bbceb99c5fe29161cf
