Is there a quick indication of parts with high tessellation quality?
james_howard360
Member Posts: 28 PRO
I was troubleshooting a relatively simple assembly with a 600ms regen time but that took 20 full seconds to reload. Finally realized that one of the parts was set to "very fine" quality; I must have used the setting and forgotten. Is there an easy indicator that shows tessellation quality without checking the appearance of parts individually?
Paul_J_Premakumar
Member, Onshape Employees Posts: 235
Hi,
You can use the performance panel to view all the parts with very fine tessellation and other performance related information. I've attached a screen shot of what it looks like. More information on the performance panel can be found here : https://cad.onshape.com/help/Content/performance_panel.htm
1
