Is there a quick indication of parts with high tessellation quality?
I was troubleshooting a relatively simple assembly with a 600ms regen time but that took 20 full seconds to reload. Finally realized that one of the parts was set to "very fine" quality; I must have used the setting and forgotten. Is there an easy indicator that shows tessellation quality without checking the appearance of parts individually?
  • Paul_J_PremakumarPaul_J_Premakumar Member, Onshape Employees Posts: 235 image
    Hi,
     You can use the performance panel to view all the parts with very fine tessellation and other performance related information. I've attached a screen shot of what it looks like. More information on the performance panel can be found here : https://cad.onshape.com/help/Content/performance_panel.htm
  • S1monS1mon Member Posts: 3,658 PRO
    You can also use the BOM panel and add the tessellation quality column to see which parts are set to the various levels.
    Hi,
  • james_howard360james_howard360 Member Posts: 28 PRO
    Ahh thank you, I had been using the regen timer window from the feature tree and missed the performance panel.
