Introducing Link tab
2»
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,014
    @Krz I can see this works fine with Chrome but appears to be some sizing happening with the css in Firefox.  Let me take a look and see if I can fix this.  Sorry for the issues.  I have not been testing this with browser updates lately.
  • Josiah_HarthcockJosiah_Harthcock Member Posts: 57 PRO
    @lougallo
    I seem to be having this issue. Any thoughts?
    @Josiah_Harthcock Have you cleared your browser cache?  Have you ever signed in with a different Google account before?  The reports I have had thus far have been related to bad browser cache.  Let me know if that works.
    @lougallo This worked. Thanks! Great addition!
  • alan_glaseralan_glaser Member Posts: 4 EDU
    Hi @lougallo! Thanks for this -- it's awesome on Chrome.
    However, I seem to be stuck when it comes to Safari. I click the "Sign in with Google" button, select the right account, type in the password, then go right back to the "Sign in with Google" button. When I click again, I can select my account again, but don't have to enter my password the second time (which makes me think it actually did the auth correctly).
    Any thoughts on what to look at?
  • romeograhamromeograham Member, csevp Posts: 715 PRO
    @alan_glaser
    Check your security settings in Preferences (the one for the whole Mac): you may have to give permission for the Google credentials to be used.
    There's a similar problem on the new macOS for signing into Google File Stream - it may be the same fix.
    This link shows what to enable...
    http://www.creativetechsupport.com/help/google/mac/filestream.html
    Good luck!
  • brooke_spreenbrooke_spreen Member, Developers Posts: 115 ✭✭✭
    Seeing the same issue as Krz with Google Sheets in Firefox (71.0)....has anyone found a workaround? The tabs opens fine in Chrome.
    Cheers :)
    Design Engineer | Anerdgy AG
  • blake_bourqueblake_bourque Member, Developers Posts: 4 EDU
    It seems that new cookie policies in chrome are breaking google authentication. Any chance this will be fixed? @lougallo
  • S1monS1mon Member Posts: 3,489 PRO
    @lougallo
    I added Linktab and went through the authorization dance successfully but I can't seem to get it to do anything beyond create a tab in a document. There's no box to enter a link.
    I can get Link Tab to ask for a URL, but I can't get anything to show up in it. I've tried a bunch of sites. They all show a sad-faced error like this:
    FWIW I'm using Google Chrome on MacOS 12.0.1
  • MichaelPascoeMichaelPascoe Member Posts: 2,500 PRO
    edited December 2021
    I didn't know this existed. Way cool @lougallo !!
    @MichaelPascoe
    Is it actually working for you? I've never been able to get it to work in Safari or Chrome.
    Is there is a way to allow anyone to view the tab as long as its a public link @lougallo?
    @S1mon
    Yes. I use Brave, its Chromium based.  B)
    @MichaelPascoe
    @lougallo
    Are you using Brave on Mac or Windows? On Brave/Mac I'm getting "accounts.google.com refused to connect" when I just add a new Link Tab to a document. I didn't even get the option to enter a URL.
    I'm sure this must work for some people, but so far I have never seen Link Tab working. What is going on here?
    @S1mon
    Windows 10
  • gonzalo_chomongonzalo_chomon OS Professional Posts: 56 ✭✭
    edited January 2022
    As others commented, I am having problem with this Link-Tab App.
    @lougallo or anyone else can have a look into it.
    Thank you in advance.
  • BLeeVNBLeeVN Member Posts: 19 PRO
    lougallo said:
    Some preliminary findings... In order for me to have your auth info saved and reused for the app, I am going to have to require a google account to do this today.  I tried to do this without that requirement but in order for the app to run on your behalf, it needs to know who you are and be able to save that.  I wanted to keep this simple and in the early staged of building it, it was going to be for Google apps only... But the workaround is to just make this require you sign into a google account might be the easy way to keep this out there for use... until maybe we build this into Onshape...
    Old Post I know... any news if this will be built into Onshape?  I cannot use Google Services in our Office.  Link Tab is a great idea, similar to MS Edge Collections for grouping Browser Pages I can see Link Tab consolidating Web Content referenced in creating a Document Part.
  • eric_poulsoneric_poulson Member Posts: 7 ✭✭
    For the many examples where this is complicated due to authentication issues, could we get a "link tab external" option that would open the link URL in a new browser tab instead of inside the Onshape tab?  (This would be less convenient than having the content appear in the Onshape tab, but would put all the authentication issues back on the browser)
  • adrian_vlzkzadrian_vlzkz Member, pcbaevp Posts: 295 PRO
    You could do that right now by adding hyperlinks in a comment
    CAD Engineering Manager
  • Ulises_FMUlises_FM Member Posts: 74 PRO
    I had partial succes getting Link Tab to properly work. For most links, the connection is rejected by the hostpage, even from popular websites such as Youtube or Amazon.
    However, the link to https://www.makeitfrom.com/ works just fine, even allowing me to navigate inside the Onshape tab.
    For the unsuccesful cases, I also noticed something odd. If I click on the "Disconnect link tab" icon on the upper left corner
    and then I re-authorise the connection of Link Tab to Onshape, two new icons appear on the upper right corner, "Open link" and "Reset".
    And the Open link button redirects me to the website opening a new browser tab.
    This Open Link button was not shown initially, only after reauthorising.
  • roman_jurt190roman_jurt190 Member Posts: 41 EDU
    Hi there! for education, having up to date google-slides with youtube videos and screenshots... (a bit like lerningcenter) would be super cool. but making it mandatory for students to have a google-account connected to onshape is just not possible. @lougallo any ideas when this could be integrated into onshape?
  • david_rubli136david_rubli136 Member Posts: 18 PRO
    @lougallo this is really a cool tool. The problem is the connection to Google, is there any update there?
