Editing a Parasolid imported file.
Hi all,
I imported a Parasolid file, I need to change the curvature of some edges of the surface. Is it possible to do that in Onshape and how?
Thanks in advance for your response.
Pat
Pat
Good Morning and welcome to the Forum!
You may be able to make your changes using direct editing or surfacing tools (depending on what you want to do). We will need more explanation to best answer. See the instructions here to share you document.
https://cad.onshape.com/documents/a42706862b5485a0d6fd3712/w/c15f51df985dc95b8cb97588/e/9a0f351f0cc97a3f194aa16d
I really hope I can get a tip or answer on what
See branch B1 in this document. Note, I rolled back to before the plane was deleted and resized for convenience to match the photo.
I changed the spinner to match the photo better. However, I do not see discrepancy in the cowling.
Please say what you think and sketch what you have in mind for the cowling. I warn you the cowling is not trivial to change; that is advanced modeling.
Best regards
Pat
