What a way to end the year, with a huge bunch of updates that are gonna make my process so much easier.
Thanks for all the active work you do!
RENDERCAD
Don't forget the self paced courses, they are good. Onshape Self Paced Courses
RENDERCAD
I use hatches a lot to show where a weld should go in a drawing. Allowing us to drop a hatch on any bounding surface would be fantastic.
Keep up the good work!
However the real utility comes when when it's possible to 'scale by reference' i.e:
1. Select a scaling origin
2. Select a feature / point on the existing sketch
3. Select new point where the original point (and rest of the sketch) will be scaled to.
I understand that there are currently workarounds but these feel like they're approximations based around scale factors not constraints.
The way transform currently works would lend itself to a very slick implementation of this capability.
Thank you!
I imagine that @jon_hirschtick 's experience with gambling may have informed some of this.
Every few weeks some new and sometimes amazing features will be announced. It's not perfectly on a schedule, so you can't be 100% sure when it's going to happen, and you don't know if the features will be ones which directly affect your workflow. It acts as a strange addictive part of a CAD system.
Finally an update focused on refining existing functionality (usability) as opposed to adding new features.
Also, the N shortcut (2nd N depress to flip) is not working.
Anyway, option to change measurement units and flipping nature of N shortcut is now working.
