dxf import to sketch?
scott_caskeyscott_caskey Member Posts: 53 PRO
Can you import a DXF drawing as a sketch?   Convert it to a sketch after you import it?    When I import dxf files, they are uneditable.
    Yes, import to Onshape, insert into sketch, then project the geometry you want onto the sketch, modify as you wish, then export again.
    How do you insert it into a sketch?
    NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,441
    jannie_smaljannie_smal Member Posts: 6 EDU
    The above is not working,This is just not working with Onshape, please let me know how to use it in a sketch! I get it in a TAB but cannot use it to make a part from it
    @jannie_smal did you click the help link above? You have to create the sketch first.
    luis_carvalho222luis_carvalho222 Member Posts: 8
    Hi, I had same problem, in this exactly moment. Was looking a way to solve it and this was i did:
    1 - Imported a coreldraw crated .dxf file
    2 - RMB on the tab imported and created draw from dxf;
    3 - Export drawing to dxf from onshape to a new tab
    4 - Imported dxf from current document.
