Convert surface into sheet metal
amir_livneamir_livne Member Posts: 85 ✭✭
Hi
Is there any option to convert that surface into sheet metal?
Amir
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,933 image
    Yes! Use the thicken option in the start sheet metal feature.
  • Jake_DelanoJake_Delano Member, Onshape Employees Posts: 43 image
    Hi Amir, use the Thicken option in the Sheet Metal Model feature to thicken the surface.
  • amir_livneamir_livne Member Posts: 85 ✭✭
    Hi
    That what I did but the "Thicken" does not accept round surfaces
  • lanalana Onshape Employees Posts: 746 image
    Onshape sheet metal does not support lofts.
  • alan_baljeualan_baljeu Member, User Group Leader Posts: 111 ✭✭
    How would you construct a surface that looks like that loft with a different command?
    Creating knowledge-driven design automation software, for molds, etc.
    www.virtualmold.com
    Hi
    Yes, that  part was build by using loft command/
    Solidworks sheet metal support loft command and I thought maybe Onshape will support it too - but it doesn't
  • wayne_sauderwayne_sauder Member, csevp Posts: 629 PRO
    Just something to think about. How would you form that? Stamping? There has been plenty of discussion on that subject and it's clear that Onshape has some work to do to support the workflow for that. If the part were to be step bent on a brake it would not have smooth curves. To say that Onshape sheet metal doesn't support lofts is not quite accurate. I will say that I do get much better results with lofted solids than lofted surfaces. I create a construction part, choose the surface I want and thicken it with sheet metal then hide or delete the construction part. Most of my sheet metal is press brake work.
  • bryan_lagrangebryan_lagrange Member, User Group Leader Posts: 945 ✭✭✭✭✭
    @amir_livne There are some work arounds, not sure how accurate this would be. You would create this loft on a press brake.
    https://cad.onshape.com/documents/b61553ca7c0d34c686ac170f/w/29eed6f7cd27da738910e958/e/8cea123d979da21145b9a64b
    Bryan Lagrange
    Twitter: @BryanLAGdesign
