Assembly instances and mates not loading
jason_traudjason_traud Member Posts: 15
This is one of the more complex designs I've put together and I'm starting to have issues with the objects in the "instances and mates" side bar not loading.
Is there likely just a network issue currently going or is this a practical limit of how complex an OnShape assembly can get?
https://cad.onshape.com/documents/4b63c675a45625f191cf7db0/w/1c40f3983f3f616177f414e1/e/e873e9533c7050129762dd17
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,904 image
    Loads fine for me - try refreshing the browser (shift + reload).
  • jason_traudjason_traud Member Posts: 15
    It's working again in Chrome today. I ended up switching over to Edge for the night and it ran fine there. The phone app wasn't having issues either.
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,245 image
    Regarding the complexity, Onshape users regularly work with designs 10x and even 100x more complex (in terms of number of instances, part complexity, etc.), so you are not close to the limits.
