Align a distance between 2 center points for a line - 2D drawing (not a sketch)
Murray_2
Member Posts: 12 PRO
Hi all,
When I select my 2 center points, I can either dimension them horizontally or vertically, but I would like the dimension to be parallel to a line that is at an angle.
The image shows what I am after. The green line is the reference line.
Any help would be gratefully appreciated.
Thanks
Murray
Thanks
Murray
1
john_mcclary
Member, Developers Posts: 4,035 PRO
I wish, but the workaround is to have a line/point dimension.
It will be parallel to the line.
So you would need to create a sketch in the partstudio that you will then 'show' in the drawing view.1 -
john_mcclary
If you right click a view in your drawing, there is a an option to show sketches. Then you choose all of the sketches you want in that view.
There are opinions it the drawing properties to change colors and stuff as well, but the colors are overridden for all sketches of that kind in the drawing.0
How do I show sketches in the drawing view?
Murray
