ONGAA for Onshape
robert_carpenter114
Member Posts: 8 ✭✭
The guys at ONGAA have developed a cabinetry Solidworks plugin. As I understand it, you 'attach' the ONGAA plugin to each component of your cabinet - and it then figures out what your Holzher, Biesse, or Homag machine needs to know in order to produce the part. If you resize the cabinet, no problem. ONGAA adjusts all the WoodWop or Biesse BPP processes for you. I was wondering - since I believe that Onshape is the brainchild of the creators of Solidworks - whether there is a way to use a Solidworks plugin with Onshape. That would open up a whole world of possibilities and transform Onshape from a cad system to a serious cad cam getter done system
1
NeilCooke
Moderator, Onshape Employees Posts: 6,007
No, you can’t use desktop add-ins in Onshape but if the ONGAA guys want to write an app for Onshape then they are more than welcome.Senior Director, Technical Services, EMEA0
