DXF Export Issues
jason_traud
Member Posts: 15 ✭
I'm trying to get a DXF file exported from a part and then import it into Carbide Create in order to cut it on a CNC. My issue is that the software I'm importing it into seems to be interpretting the MM units in OnShape as inches. I can manually scale it down however, the final scaling appears slightly off.
I'm new to the DXF format, but could there be a line in that specifies units that's not being generated properly or is omitted? I'm working with the face of part 19 in the project below
https://cad.onshape.com/documents/33b9bc333fda92b9d1e79d9c/w/e88e5eb22a9dc4d818e7335d/e/9feb284ab86b9ecd4fb5cef1
1
https://forum.onshape.com/discussion/comment/72481#Comment_72481
