How to fillet a corner of a rebate?
peter_morris
Member Posts: 43 ✭✭
I've created a rectangular block. I want to make two rebates with rounded corners on the extruded face. I've sketched their outline and can extrude them to remove the required material. I then want to round the corners. But apart from one occassion I seem unable to create an extrusion that allows the fillet tool to select the corners - I only seem to be able to select the faces. I've tried recreating what I did previously, but am unable to do so.
Grateful for any advice or suggestions.
brucebartlett
Member, OS Professional, Mentor, User Group Leader Posts: 2,148 PRO
Seem's like problem with the model, however I had no problems with the copy I played with. If you really want this resolved best to share with support. "Share" icon top right and slide the "Share with Onshape support" switch.
5 -
Narayan_K
Member Posts: 379 ✭✭✭
peter_morris ,Make sure that sketch is hidden while selecting corner for fillet.If sketch is not hidden then there is a chance that sketch may select while your trying to select corner...
7
You can also make your doc public.
Can you add a link, just cut and paste out of your browser
With out see it, sounds like your part maybe a surface not a solid.
Hopefully this link works - its call Hot-air Engine.
https://cad.onshape.com/documents/16edd4727fab4a6a98b28c87/w/a39fcc2b97c34e3a8d492ecf/e/baedefbe9bf0442ebb17fff4
for i've just managed to create a sketch on the bottom of the plate, extrude it and then fillet the corners as I required! What is the difference between a solid and a surface in this context? (happy to read the help if thats where to go).
Help!! Please.
Click inside the right hand rectangle and it should turn orange.
You can also select the whole sketch from the feature tree to get all regions,
I'm not sure that that is the cause, I've been trying to highlight the corners and then add the fillet, I've previously added adjacent faces, but it didn't help. This image is what I was struggling to achieve:
(Can't seem to add a screenshot!!)
Good Luck
Really grateful for any suggestions. Please note that I want to round the corners of the rebate and will apply a fillet in the bottom later.
Hope his makes sense.
Regards
Peter
Many thanks for the help - Narayan, I don't know whether the sketch was hidden or not, I hadn't made a conscious decision about that so perhaps that was the issue. In the end I deleted the model and created another - in much less time than it took me to do the original. Now I have other queries, which I'll research before posting a question - I suspect that most are simply my lack of understanding of what most people would call common sense!!
Thanks again,
Peter
