3DConnexion keyboard/numpad
michael3424
Member Posts: 751 ✭✭✭✭
in General
If anybody is using the above with Onshape or other programs, can you comment on how well it works for you. I'm thinking about replacing my DasKeyboard and the 3DConnexion combo is one that I'm considering.
I've never used their keyboards, so take this with a grain of salt. With 3D input devices there's not much competition, but with keyboards, there are a lot of companies to choose from. From the web site, I can see some advantages to the product, but I would be more likely to look to a bigger company with better support.
Aerospace Research & Development Group, LLC
www.aerornd.com
The only thing you get that's nice with that is the software which lets you have a bunch of onscreen soft buttons. But their drivers are so bad my experience has always been they would either hijack other devices (xbox controller for example) or they would simply reset to factory default after a few days.
Since I play video games on the same machine I work with, that got extremely annoying when at random I would be playing and then the 3D mouse would become the 'default device' while in the middle of a raid (even when unplugged). All my problems went away when I uninstalled their drivers, but then you are left with a partially working device. So, I threw it in the trash.
If you want a tactile keyboard, look into any mechanical keyboard.
you can buy one of these testers to get a feel for each switch's feel and sound before buying a whole keyboard:
Amazon.com: Griarrac Cherry MX Switch Tester 12-Key Mechanical Keyboard Sampler Switch Testing Tool with Keycap Puller and 24 O Rings, 40A-L & 40A-R (Printed PBT Keycap Include Linear Gray) : Electronics
you press the wheel down for center click
if you want a good mouse (which is thousands of times better than the 3D connexion mouse, but also dirt cheap $35)
Amazon.com: Logitech G600 MMO Gaming Mouse, RGB Backlit, 20 Programmable Buttons : Video Games
I have one at work and one at home, they are over 5 years old and still work great. The logitech drivers are a little crappy still, but the worst that happens is the speed is slow, so you open the game software and it snaps back to normal. A minor annoyance that doesn't happen very often.
But what you get is 34 programmable buttons since all buttons can have 2 things mapped at any point.
You can also set it for each application to tailor it for each app.
it looks like the right most button is small and far off to the right, but the way your hand forms to the mouse, it actually feels more like a regular right mouse button, if you're used to right clicking with your ring finger at least.
On a different note does anyone know if or how this setup would work for Onshape? https://www.contourdesign.com/product/rollermouse-red/
Especially when you need to hold modifiers like ctrl alt or shift etc ... Every time you need to take your left hand off your keyboard you lose a lot of functionality. Like keyboard shortcuts.
Even touch pads are very limiting. The best feel I've ever had was with a normal mouse, or a 3D space mouse (when it works)
