Reposition objects from Measure Tool
monkey_like_spam
Member Posts: 7 ✭
It would be nice if the tool with which we can measure would also allow us to change values. Example: you measure the distance between two boxes. Then you select and alter the X value. You then pick which object to apply the new value to. (While the other remains fixed and temporarily works as the 0 point for the operation.) This is particularly nice when you start out eyeing an assembly and then get more precise as you go. Yes, you can use mates to get precise, but it would be nice to have a spit and bailing wire tool to just work stuff out on the cuff.
