How can I make the actual moving part of a speaker in Onshape?
I've looked up pictures of speakers and I'm trying to recreate the speaker design itself in a project. I've figured out the first part, but I need help figuring out how to create an inward-curved slope from a higher surface to a lower one for the last bit.
  • mahirmahir Member, Developers Posts: 1,318 ✭✭✭✭✭
    This isn't a lot of info to go on. First, take a look at the Forum Post Checklist for the best way to help us help you. But offhand, I'd say check out the bridging curve function.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,915 image
    edited January 2022 Answer ✓
    If it’s the speaker cone itself then a loft should do it. Actually, a revolve - then you can get the entire profile created in one.
