How can I make the actual moving part of a speaker in Onshape?
matthew_bruderer
Member Posts: 1 EDU
I've looked up pictures of speakers and I'm trying to recreate the speaker design itself in a project. I've figured out the first part, but I need help figuring out how to create an inward-curved slope from a higher surface to a lower one for the last bit.
mahir
Member, Developers Posts: 1,320 ✭✭✭✭✭
This isn't a lot of info to go on. First, take a look at the Forum Post Checklist for the best way to help us help you. But offhand, I'd say check out the bridging curve function.
NeilCooke
Moderator, Onshape Employees Posts: 5,987
If it’s the speaker cone itself then a loft should do it. Actually, a revolve - then you can get the entire profile created in one.Senior Director, Technical Services, EMEA0
