Display States
wayne_sauderwayne_sauder Member, csevp Posts: 610 PRO
 Does anyone else find it slightly annoying not to be able to rename a display state, for example when you make a typo or you change your mind for a name? I realize that it is not hard to create another display state however that requires deleting the old one and going through all drawings and setting the view to the right display state again seems like a lot of work for just a typo.
 Has someone found a way to correct things like this? Is it a none Issue for most of you? I realize that a display state is somewhat of a snapshot so does that mean that editing the name should not be allowed by good computer coding standards.  Named views are the same.
 I will submit an improvement request if no one has a good solution to this.
