Failed to extrude sections, check input.
Im making a keychain for a friend, and when I try and extrude the highlighted piece it tells me to check input, how do i get this to extrude?
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,052 PRO
    hard to tell from a screen shot, for better help it is always best to link your document.
    But I would assume the two stars on the top of the C's curve are exactly touching the edge of the curve. This may be creating a zero-thickness edge.
    Try sliding the stars down slightly using transform and see if that works.
    (or make those two stars construction lines so they are ignored for now)
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,987 image
    It will be the stars at the top that touch the edge of the logo - they are creating non-manifold edges (you don't want to know, other than this condition is not allowed). Move them slightly in the sketch so that they either keep or remove a small amount of geometry and it should be OK.
  • andrew_kleinertandrew_kleinert Member Posts: 97 PRO
    I came across a similar problem.
    It was complex geometry that was triggered by a variable change.  Suddenly my parts became a sea of red "Boolean Operation failed to return a valid part" for no obvious reason.  A bunch of time was spent pulling the design apart to deconstruct what was going on, googling lots, a bit of learning about what "non-manifold edges" are before I figured it out.
    I have reconstructed a very simple instance of the problem below ...
    Link to doc: https://cad.onshape.com/documents/1e38feb1afe46c1dc690dff0/w/029a649ba1e9e14491d9f344/e/0d748252251589fca813f209?renderMode=0&uiState=620af2609861fd1f00fd2869
    @NeilCooke , a few questions about this ...
    The system doesn't seem to be very helpful:  "<Tree item> did not regenerate properly:  Boolean operation failed to return a valid part" isn't a helpful error message for something that is physically realisable (within tolerance).  Plus there appears to be a lot more coloured red than needs to be (should it only be the singular non-manifest edge that is indicated red?) - and this gets a lot worse very quickly for more complex shapes.
    ... Should I raise an improvement request?  If so, should it be "Fix non-manifold edge / point handling in renderer"? or "Improve UX around non-manifold edges / point errors"? or something else?
  • S1monS1mon Member Posts: 4,061 PRO
    This is a fundamental issue with the Parasolid Kernel that Onshape, Solidworks, NX, and countless other systems use. You basically can't have two bodies join at a line. There needs to be some small amount of overlap.
  • Nic_JNic_J Member Posts: 14 EDU
    I believe you must move the starts connecting with the highlighted piece. They're what stop the extrude from happening.
    Thanks for this 👍
    I do wonder if the CAD system is able to be more helpful though?  Does the parasolid kernel return error details that can be of more help to the user?
    The example I posted above is a fairly simple and a more obvious one.  But when the design is more complex, and the issue arises from a variable change, it can be frustratingly difficult to figure out what is going on (well, it is for me anyway 😀)
    Anyway, this is all in the spirit of continual improvement - I’m not complaining.
