The drawings are not generating
mario_darceuilmario_darceuil Member Posts: 113 ✭✭
Please look at the tag below and see that it is not generating, I don't think my MAC is the problem. Please help.
  • mario_darceuilmario_darceuil Member Posts: 113 ✭✭
    Gee i thought i extruded them to 1/16 or  1/32 inches decimal.Thanks. I created one fin and used the linear tool to get the others. Do i used merge or make coincident with the tube to attach them?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,929 image
    That's because you made the fins from surfaces that have zero thickness and are not attached to the tube - you need to create thin solid extrude features.
    Just use the “add” option in the extrude dialog.
