Native NX import
ralf_zervossralf_zervoss Member Posts: 4
Hi there,
I am looking for a good option to handle native NX files from our clients. Does Onshape support import from latest and greatest NX version? All forum entries about this topic seemed pretty old already. Thanks for your help and stay safe!
Ralf
  • dirk_van_der_vaartdirk_van_der_vaart Member Posts: 552 ✭✭✭
    This is from the help file, the ? in the right upper corner.
  • TimRiceTimRice Member, Moderator, Onshape Employees Posts: 315
    Currently we do support:
    Parts - NX UG15.0 through NX12.0.2.9, NX UG 1911, NX 1915, NX 1919, NX 1926 through 1946, NX 1965, NX 1969, NX 1973, NX 1847, latest version NX 1847.2400, NX 1851, NX 1980, NX 1984, NX 1988, NX 1992, NX 1996, and NX 2000
    Assemblies - NX UG15.0 through NX12.0.2.9 (via a .zip file), NX UG 1911, NX 1915, NX 1919, NX 1926 through 1946, NX 1965, NX 1969, NX 1973, NX 1847, latest version NX 1847.2400, NX 1851, NX 1980, NX 1984, NX 1988, NX 1992, NX 1996, and NX 2000
    For the full list please see this article:
    https://cad.onshape.com/help/Content/translation.htm
    Onshape, Inc.
  • S1monS1mon Member Posts: 3,298 PRO
    Also keep in mind that Onshape, NX and Solidworks (and others) use Parasolid as the native 3D kernel. So, if for some reason you can't get native parametric files, you may be able to get Parasolid neutral files. This would typically be preferable to STEP or IGES.
  • ralf_zervossralf_zervoss Member Posts: 4
    Hi guys, thanks for your hints. Our client simply exports the native files from their PLM system, so any neutral format won't work. I'll try to find out about the exact Siemens NX version, they are using. Are these translators also available for testing in the free plan to be able to check the quality?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,848
    Yes, you can use the free plan, but you should not upload your clients' data to the public domain - ask them for a test file. The latest version of NX is 2008 (Dec 21) which we don't officially support but it may still work.
    Hi Neil, of course. We will use a test part or some nuts & bolts for testing. I'll give it a try a soon as I have got approval.
    Cheers
    Ralf
