No attachments here?
S1monS1mon Member Posts: 3,777 PRO
I tried a few times today to post to the "Product Feedback" category with a couple of in-line images. I got an error that they aren't allowed here. Previously I have posted with images in this category just fine. I was able to post the same thing to "General".
  • Nath_McCNath_McC Member Posts: 135 PRO
    I also got this error when I tried to post my render feedback. it seems a little backward as sometimes is just as easy to post an image to show the feedback you at writing about.
    My guess is there is some sort of automatic reader that is reading these posts to sort assign a person to and it will not pick up images. I could also be barking up the wrong tree.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,933 image
    Seems to be working for me - can you try again?
  • Nic_JNic_J Member Posts: 14 EDU
    Yeah, I can't do it either.........maybe you're the only one allowed @NeilCooke ???
  • alnisalnis Member, Developers Posts: 452 EDU
    Test image:
    Maybe the required image format is different? PNG vs GIF vs SVG vs JPG vs ...
