Render Studio - First Impressions
Nath_McCNath_McC Member Posts: 114 PRO
edited February 2022 in General
I would like to create a thread of people's first impressions. I have been messing around with the beta version and I'm very impressed.
Adding the assembly is straightforward enough. Overall when assigning textures it seems a little bulky as it is updating in real-time and I can imagine it being quite slow if you a have high part count assembly. There are a lot of textures which is great. I believe that my quick mockup looks very much like the real item on my desk. Great work to all involved.
    mj_powersmj_powers Member Posts: 18 PRO
    My first impression is the interface is easy to navigate and there are quite a few standard materials.  That being said, there are a few things that i'm accustomed to with Keyshot workflow that I did not find. I may have overlooked it.  1. save materials  2. copy and paste materials 3. create custom materials 4. create/add labels  5.manipulate surface textures.  6. PMS color picker.  I work on a lot of projects that require custom textures and would not be able to use the render engine as is currently offered.
    shawnrwshawnrw Member Posts: 43 PRO
    Looks really good! Btw, does anybody know how to rotate an assembly so it is orientated to the ground correctly?
    NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,432
    Hold down Option/ALT while rotating (just like in Onshape)
    mark_quadlingmark_quadling Member Posts: 2 PRO
    I've never done any rendering before, and was surprised at how easy it was to use.
