It allows you to place multiple instances by mate connector so you don't have to use Transform afterwards.
var myNewVariable = {value:5 * meter, description: "the length of my imagination"}
Between the integration and improvements with Frames and the batch export, I think you just saved me an additional hire.
Also thanks as usual guys
doesn't matter if parasolid has a function, you guys enabled it for us
I see that the trim boundary is 2 dimension and degree 1 or degree 2. I was curious to why also, so I ran a test to see what they were. and interestingly, they are the parameters for evFaceTangentPlane. Well they were for a few of my surfaces. Some are just having odd results.
With this, I was able to create the trimming curve for the B Spline surface. Now if only there was a native imprintEdge function.. Hmm.
It would be helpful for lumber to output the cutlist in fractional inches: There is no 0.875 on a tape measure.
Also the two angles listed are ambiguous - is that on the wide or narrow end of a 2x4? There doesn't seem to be any way to clarify in the cutlist without a diagram & callout
About copying and pasting drawing views, could it be possible to extend this update to section views, aligned section views, and auxiliary views too? Seems like these should have been included in the improvement.
Thanks!
Rendering, Frames, you guys are really spoiling us these days!
Now just give us a native 3D Sketch so we can really rock those Frames
