sweep 3d fit spline
hervé_pipon
Member Posts: 60 ✭✭
Hello
I want to sweep a circle along a 3D fit spline...
The part stays red but I dont know why it doesn't work
Can you give me some clues
https://cad.onshape.com/documents/e8d2062de0ff95f77a6b4b37/w/88f7579ccec47391700eef0d/e/11c1c545df40cf3e4129269f?renderMode=0&uiState=62166a218a7f740bc888c9bb
imants_smidchens
Member Posts: 73 EDU
as far as I can tell, the issue is that "Sweep 2" creates a self-intersecting part at one end. Zooming in reveals the problematic geometry with the curve with the sweep profile running into itself.
this can be solved by adjusting the start magnitude in your 3D fit spline from -0.037 to at least -0.051 (anything larger will also work)
2 -
GregBrown
Member, Onshape Employees, csevp, pcbaevp Posts: 385
It looks like a combination of the 1) diameter of the sweep profile (in Sketch 9) is too big, and 2) the curvature (Start Magnitude) in 3D Fit Spline 1 is too low. I can get it to regenerate with some tweaking...hervé_pipon said:Hello
https://cad.onshape.com/documents/e8d2062de0ff95f77a6b4b37/w/88f7579ccec47391700eef0d/e/11c1c545df40cf3e4129269f?renderMode=0&uiState=62166a218a7f740bc888c9bb2
When I asked for the end of the sweep to be normal to the face, if became extremely unstable and I chose to turn the norm constraint off.
My solution, which I haven't done yet was to trim/move/boolean the sweep to the face making this operation into 2 features vs. just a sweep. I didn't test this solution for robustness and need to.
boolean subtract:
This is what I'd do. It seems to be the cleanest and will be my solution when I get some time to implement.
split part:
Split worked but you'd have to follow up with a delete body and figure out which body to delete.
move face:
This doesn't work very well.
This means you could rewrite the sweep feature and call it robust sweep to handle the end condition. Have you tried feature script?
