Hollow out a solid does not work, what am I doing wrong?
dana_kelley262dana_kelley262 Member Posts: 31
edited February 2022 in Community Support
I'm having trouble with hollowing out an organic shaped comprised of two sculpted solids lofted into a single part.
https://cad.onshape.com/documents/9a417b0697da9936af13424a/w/0fc8dc7a76c3ee728c5fc22d/e/78c24629c01ea91da3b419ca?renderMode=0&uiState=621658870967dd12d977c374
  • dana_kelley262dana_kelley262 Member Posts: 31
    @wayne_sauder, loft Normal worked except the profile between was not what I wanted.
    I took each piece, shelled, then Boolean them together. This worked.
    @John_P_Desilets, I did the sculpture in two sections so to get the base the desired shape and then the Top. Doing both at once was not all that easy. Adjusting the top messed with the bottom. Thinking it over now. I could have just drawn the top, but that too is difficult with splines. Is there an easer answer then splines? Sculpture is sort of easy and organic where splines are not.
    Trying out Blender for organic objects
  • wayne_sauderwayne_sauder Member, csevp Posts: 628 PRO
    @dana_kelley262
    One option is to set the start and end profile conditions to normal to profile in your loft 1 and 2.
  • John_P_DesiletsJohn_P_Desilets Onshape Employees, csevp Posts: 262 image
    @dana_kelley262 You might get better results if you loft several profiles at the same time instead of smaller sections. This way the shape is more uniform. After the loft, apply the sculpt face feature and shell as a last operation.
    Document
    Loft all three sections at once
    @dana_kelley262 Drawing each profile using splines is probably your best option. Organic shapes like this are tedious and require a lot of geometry to create.
    @dana_kelley262
    Have you considered Phi? See the app store.
    @John_P_Desilets,  I see one spline. Is there more? Would you mind sending a link to that document?
    @wayne_sauder, I looked Phi. $125 per month. I'm a hobbyist and cannot justify the expense for the amount of use. I did reach out to verify. Phi is looking into adding more affordable price options for hobbyist/non professional use.
    You don't need to use a custom feature.
    You can configure the text
    Oops, sorry this comment was for another post
    Un saludo,
