Why won’t my sketch extrude?
OptionsMatthew_Curran Member, csevp Posts: 19 PROExtrude requires a closed loop in a single sketch in order to create a solid part. In your part studio you have many sketches that create a single closed loop which will not be recognized as a closed loop in the extrude feature. What you can do is create a new sketch on the right plane and use the Use (Project/Convert) feature to project all other sketches to this sketch, then use this sketch to extrude a solid part.
https://cad.onshape.com/documents/4afbf34b2ddb01f90c6080a9/w/5464a25b12c8f94e9773984d/e/6334074fc92ccac5054b8ac9?renderMode=0&uiState=621f4fd756b65479050e5c69
2
