how to insert an image into a drawing
Andrew_Michell
Member Posts: 6 PRO
I am trying to put an image in a drawing template.
I am following "inserting images" in these instructions: Best Practices for Creating Onshape Drawing Templates - Onshape Learning Center
After selecting the image, I drag from a point to insert it, but nothing happens.
What am I doing wrong?
MichaelPascoe
Member Posts: 2,818 PRO
Sketches, part studios, and assembly studios are lightning fast. Drawing sheets can sometimes be sluggish, this is typical.
RENDERCAD
________________________________________________________________________0
RENDERCAD
RENDERCAD
Looks like you have already found the learning center. A tip I wish I knew starting Onshape: Complete each of the Learning Pathways, I have learned so much from them.
RENDERCAD
