Problem Part outline
@Onshape Below is a pic of a drawing in which a section of the part outline is missing (circled). There are two parts in this drawing one is the actual part and the other is the material as machined at this operation. I am placing the issue here because Usersnap is not working. I also shared the document with Onshape (23055960-203 - Copy). This drawing is in the far right tab. This document is a copy so do with it as you need/wish.
Thanks
Dave
Thanks
Dave
Thanks
