simulation help and instruction
WJTWJT Member Posts: 6 PRO
The email references a video in the "Notes on mates" section but I don't see a video.  Where can I find the video?  Also, the link for simulation help directs me to the enterprise landing page and not the simulation landing page embedded in the hyperlink.  I have tried incognito, clearing cache, signing out, etc.
I am attempting to simulate stresses from internal pressure on a vessel assembly that is screwed together but not having any success so far.
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,016 image
    I added the video to the welcome post.
  • Kevin_CowlesKevin_Cowles Member, Onshape Employees Posts: 50 image
    @DIWJT
    What are your issues with the pressure vessel assembly sim? Is it with regards to applying the pressure load, or with the convergence of the result? I would definitely recommend double checking your mates to make sure that your DoF are completely defined
  • H_WangH_Wang Member Posts: 20 ✭✭
    Hi, today I just had access to simulation, I am so excited to get started. However, I haven't been successful because I think I am missing the FGS Material Library. How do I get that loaded? I tried to add it in but could not find it anywhere. Please help!
  • Jenny_JohnsonJenny_Johnson Member, Onshape Employees Posts: 9 image
    You should have the link in the welcome email to the EVP
    Jenny E Johnson
    Principal Technical Services Engineer, Onshape
    jjohnson@ptc.com
    edited March 2022
    I have already activated simulation using the link provided in the welcome email. It is an issue I encountered after I start using it. I have everything else except the FGS Material Library, which I think is stopping me from running the simulation.
    I figured to make it clearer, I snapped a screen shot
  • chris_gromek_onshapechris_gromek_onshape Member, Onshape Employees Posts: 26 image
    Please use the link below to find a public document of the model shown in the training video.  This document contains the simulation materials library, which you can add to your list of material libraries:
    https://cad.onshape.com/documents/2562520323bae377dc30978b/w/284d5051907d4e72efeee88a/e/7931e6c34a6c41c716f758cc?renderMode=0&uiState=62290e68d47a3132a2425203
    If you saw the picture I posted above, I have already done that. But that is the result I got, the FGS Material Library is still missing, if it was contained in the supplied document, how do I extract that? Thank you!
    This is the message I got when I tried to add the library.
    Greetings and my apologies for the difficulty.  Please follow the steps below and let me know if anything still appears amiss.
    Best!
    Chris
