Filleting a sketch causes a previously fully constrained sketch to become unconstrained
Gary_32
Member Posts: 3 ✭
The sketch was fully constrained and showing as all black.
I presume that the fillet has removed a bit of the end of a line that was used as a length constraint in the pattern - but surely it should just use a virtual intersection point if a fillet is applied to an intersection of two lines?
Then I added 0.5mm fillets to all the intersections
Then the sketch became unconstrained and showed red
It seems to me that the fillets have broken the pattern constraint that I used to create the cut-outs in the sketch?
Surely this should not happen?
Further, how do I go about fixing the broken pattern constraint - can I adjust the points/line that the constraint was originally patterned with?
Even if you apply fillet by corner point selection method it should not over constrain the sketch...It may having some problem...
TVP, Onshape R&D
TVP, Onshape R&D
